engine modifications
Old Jun 1, 2004 | 08:37 PM
roxzee's Avatar
I have a 94 Z28 LT1 enigne. I'm about to pull the engine because of a slight rod knock that is starting to get worse. I'm purchasing the LT4 conversion kit (LT4 cylinder heads, LT4 intake, and a Hot Cam). I was hoping to get some ideas for some modifications on my block for more horsepower to add to the conversion kit
thanks!
Old Jun 1, 2004 | 08:41 PM
QCKZ28's Avatar
why the lt4 conversion kit?
you can make LOTS more hp/tq with a better cam and having your heads professionally ported/polished.
get a set of headers also while you are there, change over to an electric water pump, and run a double roller timing set.
you could always do a 383 stroker
Old Jun 2, 2004 | 09:25 AM
roxzee's Avatar
383 stroker
okay, so i have my cylinder heads ported and polished, but what about the intake manifold, any modifications there? and what cam should i go with?
can i modify my LT1 engine block to a 383 stroker? what would that consist of? boring out the cylinders and replacing the pistons?anything else?
Old Jun 2, 2004 | 09:44 AM
Red96Lt1's Avatar
You have to do some other machine work to the block to clear the rods. For a little more money than the the LT4 kit, you could get headders, P&P your heads, get a cam, pushrods, lifters and some 1.6 RR's. You could be putting around 400 to the ground. Do a stroker if you have about 5k to spend.
DirtyDaveW
Dec 1, 2016 05:37 PM
Sergio
Jan 27, 2016 04:27 PM
Lonemechanic
Feb 19, 2015 10:29 AM
