engine idle need help!!!!
Old Jul 20, 2006 | 10:47 AM
larryndog's Avatar
I have an 02 camaro and it idles rough when the a/c is on what should i do....help
Old Jul 20, 2006 | 11:00 AM
ChevalierSS's Avatar
Re: engine idle need help!!!!
I'd start by changing the fuel filter, air filter, and then dump some fuel system cleaner in the tank just as a preventive maintenance. If that doesn't work check your fuel pressure and investigate further.
Old Jul 20, 2006 | 02:58 PM
Welcome Larry....
We have a little bit of organization to the forums, and prefer that you post a question ONCE, and only in the correct forum. You've got this one scattergunned in 4 different forums, including:
-V6 Tech
-LS1/LSx..... Tech
-LT1/LT4..... Tech
-General F-Body..... Info.
Obviously, if you have an '02, its not an LT1 so this post doesn't belong here, so I'll close it.
Decide what kind of an engine you have, and put your question in the correct forum. It helps to add a "signature" with the year of the car, engine type, tranny type, and any major modifications, so people can answer your questions accurately.
STR FTR 1
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:36 PM
edman
Jan 25, 2015 02:41 PM
David Dorris
Jan 17, 2015 08:10 PM
Lions3
Apr 11, 2003 10:55 AM
Hot Rod Hawk
Aug 15, 2002 10:47 PM
