engine hesitating at wot..
Old Jan 6, 2007 | 08:52 PM
ZX636RIDER03's Avatar
so i attached the fuel pressure gauge today to the line and made it stick out the hood so i could see it. when i would turn the ignition key on, the pressure needle would barley move, after a couple turns of the ignition the pressure would finally rise. then i decided to take it for a spin at wot, so i would start at about 2500rpm in 2nd then i would punch it. as the rpm's would rise the fuel pressure would gradually drop to about 30-35psi and then it would hesitate again and then keep going to redline. so does this mean that the fuel pump cant keep up?
Old Jan 7, 2007 | 09:08 AM
Could be the pump, could be the fuel pressure regulator. Unless you had the pressure gauge line pinched by the hood.
What did the gauge read at idle - 1) with the vacuum line attached to the FPR; 2) with the vacuum line removed? Did you take any pressure measurements at all without the hood closed on the gauge line?
Old Jan 7, 2007 | 09:14 AM
Guest47904's Avatar
Guest
Your fuel system appears to have a problem but it doesn't have to be the pump that is the cause.
Could be a filter issue or the sock in the tank. Could be the line from the pump to the tank connection is leaking. Could be a FPR problem.
Since you have an Aero FPR, I would suspect it first. SEVERAL people including me have had problems with it.
Feffman
Oct 9, 2015 05:42 AM
jayblev95
Jan 20, 2015 01:30 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
Queens94z28
Dec 20, 2014 09:11 PM
IRABuss
Sep 7, 2011 09:08 PM
