Engine dip around 3400-3700RPM
Old Mar 22, 2004 | 10:29 PM
JSK333's Avatar
I think I've finally narrowed this problem down to something mechanical, but I'm not sure where to start now.
I have a slight hesitation around 3400-3700 at WOT. I confirmed this from scanning it and seeing the MAF sensor show a drop in airflow in this RPM window.
It is also the same range where I got knock on the nitrous.
Timing is the same through this range, as if commanded AFR, so it seems something internal is causing a change in airflow.
I actually also get a similar symptom around 4600-4800RPM.
Where should I look/what should I do next?
Old Mar 23, 2004 | 04:34 AM
slopokrodrigez's Avatar
Have you looked at fuel pressure at the point the problem occurs?
Old Mar 24, 2004 | 10:26 AM
JSK333's Avatar
Yep, a few times, and it looks normal, as do the O2 sensor values.
STR FTR 1
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:36 PM
Scottylt1
Jan 8, 2015 02:48 PM
Cam's maro
Dec 29, 2014 08:44 AM
Scottylt1
Dec 4, 2014 12:31 PM
