Engine died with boom and puff of white smoke ---
I havent had time to do anything besides try to start it and look it over for holes, lol.
I was going 25mph , shifted from 1st to second then BOOM (exhaust backfire I think) and the cop said a BIG puff of white smoke out the exhaust.
No holes or leaking of fluids.
When I try to start it , it cranks WAY faster than normal. It backfired one time, pretty small ... out the exhaust after about 30 seconds of cranking (that should rule out the opti right?). If its the head gasket check the oil?
Does it sound like a busted timing chain? The guy told me it was replaced, but he has lied about other things ... and the car has 143k miles.
If it is the timing chain did I damage the internals? I have all new ones purchased already for my le2 build that I keep stubbing my toes on. Now is a great time to get that installed, hahah.
Thanks for the help ---
https://www.camaroz28.com/forums/sho...t=timing+chain
Mine did something similar when my opti died recently. I was going about 35MPH at the time, and got some KILLER backfire. Don't know about the smoke though. Try a scan, see if you get the lo-res pulse code for the opti, or pull a plug, ground it, and test for spark.
Thats sounds like exactly what happened when my opti went, i was going 90MPH down the interstate and then it sounded like a shotgun went off under my hood and white exhaust came firing out the back. Check to see if ur throwing sparks where it shouldnt be going, and i also recomend some new MSD cords and new plugs
Well what was it? The suspense is killing me. A mighty boom and a puff sounds about right if you're talking about a cannon but it sounds not so good for an engine. The booms and puffs are supposed to be inside the block.
Alex Barnes
Jan 24, 2015 10:21 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
