Engine Stalling
Old May 21, 2008 | 05:19 PM
rwing7486's Avatar
Engine Stalling
my 94Z keeps on stalling on me. The car will start up fine and run perfect until the car reaches operating temperature where the engine just dies. When I start the car back up the car will run fine for about a few seconds while the SES light comes on and then the tachometer will start jumping around has the engine struggles to stay running and the car starts to shake and u can hear puffs coming out of the exhaust. Ive talked to autozone, murrays, advanced auto parts, and NAPA trying to rent an OBD1 scanner but all they have are OBD2. I did find this 12pin ALDL that might work and use my laptop, but im an unsure whether or not will work. What is the cheapest way to pull the codes??? I am thinking its a throttle sensor , coolant temp sensor or an O2 sensor. Please help me cause this problem is starting to drive me crazzy!!!
http://www.aldlcable.com/sc/details.asp?item=aldlobd1u
Old May 21, 2008 | 08:57 PM
pro94lt's Avatar
strip back both ends of a short wire and put them into the top farthest to the right metal pins where you would hook the scanner on. turn the key on and it should flash you your codes.
Old May 21, 2008 | 09:29 PM
rwing7486's Avatar
it doesnt work for the LT1 engine...only for the 6 clyinder.
Old May 21, 2008 | 10:06 PM
pro94lt's Avatar
well maybe thats why I cant get any codes out of my car. I have tried with the scanner and no codes, with the striped wire I get the same results, fans come on, relays click so what is the proper way of doing it? thats what i've always done on all my old gm trucks and cars. this is a 12 pin 94 lt1 I have
Old May 21, 2008 | 10:47 PM
93 LT1 is the only one that you can flash the codes by shorting the ALDL pins. Doesn't have anything to do with how many pins it has. 94/95 require an ODD-I scanner like the AutoXray, or software like Freescan or TTS DataMaster. Both those software packages are free downloads. You just need a cable. DataMaster is only good for 20 uses, and then it will ask you to license it.
Old May 21, 2008 | 11:11 PM
rwing7486's Avatar
ya i have the FreeScan software on my computer and am just trying to find the 12 pin cable as cheap as possible
Old May 22, 2008 | 10:06 PM
pro94lt's Avatar
It all makes sense now. I've been using the useless wire trick for three years now and never got any codes out of it.
RUENUF
May 25, 2016 08:10 PM
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
Injuneer
Dec 15, 2014 09:36 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
ARFFormula
Aug 3, 2002 09:55 PM
