Engine Cutting out.....?
Old May 17, 2003 | 04:10 AM
SSnakeEater's Avatar
Question Engine Cutting out.....?
when i am slowly putting on the gas around 2000 RPM the engine hesitates and cuts out a few times like theres a miss or something. it jerks back and forth but it only does it about two or three times a day and it does it at idle when i first start it to warm it up in the morning.
could it be the spark plugs? do i just need a tune up?
or is it something else like the opti or something?
thanks for all of your help
Old May 17, 2003 | 06:17 AM
badass383's Avatar
disconnect the EGR vac line and plug it and try it for a few days. If that's not it, try checking and cleaning the IAC. Check the vac line to the fuel pressure regulator to see if it's wet. If it is, you need to replace the fuel regulator.
Doubt it's ignition but if the above things don't cure the problem, consider replacing plugs wires or opti if they have over 60k on them.
Never hurts to check fuel pressure and don't forget the fuel filter too.
Old May 17, 2003 | 01:07 PM
i am not quite sure where the EGR vac line is.... or the IAC, or the vac line to the fuel pressure regulator??
is it possible to take it to autozone or something to check it for codes?
and my car only has 50k miles on it, i am confused if its the opti going out...?
97z28k&N
Jan 9, 2015 04:58 AM
Jan 5, 2015 07:14 PM
cmdeshon
Dec 12, 2014 10:51 PM
formula218
Dec 2, 2014 04:27 PM
