Engine cutoff problem
Old Jan 17, 2010 | 07:18 PM
edz97's Avatar
I was thinking that this was a fuel pump problem because in neutral the engine will rev to the redline. When trying to drive it, the engine cuts off at 2000 rpm and needs to be restarted. I taped a fuel press gauge to the windshield and drove it. The pressure never dropped below 41 psi even when it cutoff. The only codes thrown are 102, 335,336.
Anyone have this problem or know what it could be?
Old Jan 18, 2010 | 05:16 AM
P0102 indicates the MAF sensor signal is less than 1,000Hz, which could mean its not functioning. Could be a problem with the pink wire in the harness connector - a common problem on the 97's. Check the pink wire for +12V (key on, engine off, harness unplugged). Measure from the pink wire to the black/white wire (ground).
The other two codes are for the crank position sensor. While the sensor is only used for misfire detection, the diagnostics are based on the sensor duty cycle, and there have been cases where problems with the Opti pulse signals have caused the CKP codes to set. Check the CKP sensor first.
Old Jan 18, 2010 | 06:23 AM
edz97's Avatar
Thanks for the detailed info.Is there a way to check the ckp or should I replace it?
Old Jan 18, 2010 | 09:06 AM
edz97's Avatar
There is 12v present between the pink and blk/wht wires on the MAF sensor connector. I took the MAF off and sprayed MAF cleaner on it, still throwing the code.
Old Jan 18, 2010 | 12:12 PM
Swap it out temporarily with a known "good" MAF sensor, to see if your MAF sensor is deceased.
You are clearing the codes before rechecking them, correct?
Old Jan 18, 2010 | 03:52 PM
edz97's Avatar
Yes, I am clearing the codes.
Old Jan 19, 2010 | 09:26 PM
edz97's Avatar
I put a new MAF sensor and voila, problem solved. I still have the ckp code, will this affect passing obd 11 emissions test?
Old Jan 20, 2010 | 05:31 AM
If it turns on the SES light, some states/areas will not pass you. Depends on state/local inspection regulations. It won't cause any change in emissions, though.
Old Jan 20, 2010 | 05:18 PM
edz97's Avatar
Is there a way to check the connector wiring to the CKP, or is it typically the sensor that is bad?
Old Jan 22, 2010 | 05:57 AM
Guest47904's Avatar
Guest
With KOEO, measure 12 volts from the pink/black wire to the pink wire. The yellow wire goes to the red PCM connector pin 1.
Old Jan 29, 2010 | 06:34 AM
edz97's Avatar
OK, so I checked the CKP connector and have 12v there and the yellow has continuity to the pcm. I then replaced the CKP with a new one. Cleared the codes and the cel is on again. wtf
Old Jan 30, 2010 | 07:40 AM
Guest47904's Avatar
Guest
Something to do with the mounting/contamination
I think it is a common problem with either the mounting or some sort of contamination. Do a google search.
Old Jan 30, 2010 | 07:44 AM
edz97's Avatar
I'll try that, thanks for your help.
Old Jan 30, 2010 | 08:49 AM
And is the check engine light giving your the same codes?
Old Jan 30, 2010 | 06:23 PM
edz97's Avatar
You are correct sir. I assumed that the CKP was still the culprit, but I scanned again and now codes 1641 and 1642 are present. I found a blown fuse, #7 under the hood. Must be a short somewhere. The car is running very well though. Just barely over 1/4 throttle and the rear tires want to break loose. I know the fans will not function with the problem, but its been so cold here that the temp stays below the halfway mark.
edman
Jan 25, 2015 02:41 PM
Alex Barnes
Jan 24, 2015 10:21 PM
InfernalVortex
Jan 17, 2015 09:35 AM
HCz28
Jan 11, 2015 11:21 AM
97z28k&N
Jan 9, 2015 04:58 AM
