Engine Connectors and DLC Wiring
Old Sep 17, 2010 | 12:15 PM
ulakovic22's Avatar
I'm wiring back together a 97 T/A and I have some questions. I have an OBD2 engine harness but it's missing quite a few pigtails. I'm wondering where I can find a schmatic that tells me the orientation of the MAF and Coil wiring. Last time I got pigtails for the CPS all the wires were white so I can't just match up the colors. I have a wiring diagram from Shoebox and my Haynes manual so I know what wires I need, just don't know the orientation to the connector.
I noticed that the connectors on the RH shock tower get power from the fuse box on the LH side of the car. Do I need to run fused power to the connections on the RH shock tower for the appropriate sensors and such? I'm guessing I do so the PCM will get power.
On the DLC, I've traced all the wires I need so I can still use the DLC for inspection and diagnostic purposes, but I want to make sure that out of the 16 pins, only 2, 4, 5, 6, 9, 16 are used. I notice that 8 is marked to the keyless entry system, is it necessary to pass inspection? Will it hurt anything to not have it?
Thanks!
Old Sep 17, 2010 | 04:46 PM
All that info is on my site. The A,B,C...cavities are shown and the plugs themselves have that marked on them.
If a wire says it is supposed to get power from so and so fuse, then wire it to the fuse that is supposed to be powering it (am I missing something?)
The wire for the keyless is not used on 96-97.
Old Sep 17, 2010 | 05:40 PM
ulakovic22's Avatar
You're not missing anything, but my car has ZERO wiring in it except for the engine/trans harness I just put in. I have no fuse box or anything so I'm trying to figure out what I need to get the car started and AutoTap hooked up so I can see what's going on and of course so someone can adjust the tune.
I looked on your website and all I could find was OBD1 stuff. I know the MAF is the same, but the coil isn't. I'll check again later after I get back from the kids football practice.
Old Sep 17, 2010 | 06:32 PM
Nearly all the PCM wiring and sensor stuff is the same. There is also a 96-97 ignition schematic.
Old Sep 18, 2010 | 09:00 AM
ulakovic22's Avatar
Can someone confirm that the coil connector only has two wires? According to this schematic I only need the pink and dark green wires, but the coil has three prongs and the connector is a three prong.
http://shbox.com/1/1996_ec_03_ign_system.jpg
Old Sep 18, 2010 | 09:10 AM
Sounds like you have a 94-95 setup with the dual-connector coil, but you are using the wiring diagram from a 96-97 single-connector coil:
http://shbox.com/1/95_ign_system_schematic.jpg
Old Sep 18, 2010 | 09:34 AM
ulakovic22's Avatar
It's a 96/97
IIRC from my 97 Camaro, it's a three wire connector and the coil has three prongs. Sorry for the questions and confusion, but I'm working with a hacked up harness.
Old Sep 18, 2010 | 10:26 AM
A 93-95 has a coil with 3 pins, and requires a "dual" (one part gray, one part black) harness connector to match. A 96-97 has a coil with 2 pins, and reuires a "single" harness connector to match. Can't really explain it any more clearly than that.
Look at the 96-97 wiring diagram you posted..... 2 pins, A and B.
Old Sep 18, 2010 | 10:31 AM
ulakovic22's Avatar
Ok, thanks. I was just looking for confirmation that the 96-97 coil only uses two wires even though it uses a 3-way connector and the coil itself has three prongs. I didn't realize one of them was not used.
Do you know if it uses the same metri-pack connector as the MAF?
Old Sep 19, 2010 | 10:39 AM
ulakovic22's Avatar
MAF and Coil connector are not the same Metricpack 150.
Richardan15
May 30, 2015 08:36 AM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
Jul 4, 2005 05:00 PM
Brett 91 RS LT1
Mar 12, 2003 10:02 PM
Omega9
Aug 2, 2002 12:33 AM
