Engine code p0601
Old Jul 20, 2005 | 11:53 AM
Canuck wita WS6's Avatar
Engine code p0601
Anyone know what this code actually means? I searched through obd2 codes and it says PCM memory, or Internal Control Module Memory Checksum Error.
The car is popping out the exhaust on decereration and everytime i shift and let my foot off the gas.
I replaced the opti in the spring, which resulted in the popping in the exhaust and a high rpm miss. Symptoms before i replaced the opti were stalling and opti codes being thrown by the pcm.
I just recently replaced the plugwires in hopes of curing the popping and miss, which it didn't.
The car stalled and set this code when i took it for a test drive after installing the new wires.
Could it be a bad opti? Seems logical with all the symptoms, but why did i get this p0601 code?
Car has intake and full exhaust, along with a madz28 tune. So there are no internal engine mods that might lead to these symptoms.
Old Jul 20, 2005 | 02:09 PM
moparman's Avatar
Re: Engine code p0601
Usually that means a bad PCM. Check with Madwolf about it.
Old Jul 21, 2005 | 04:07 PM
Anyone else had a similar issue?
Jul 4, 2005 05:00 PM
centric
Aug 15, 2002 09:04 PM
91Bird305
Aug 5, 2002 01:39 PM
z28projects4ever
9
Jul 16, 2002 07:48 PM
jrp4uc
Jun 19, 2002 06:20 PM
