Engine clicking noise...runs terrible :(
Old Mar 5, 2008 | 07:04 AM
sskilla9three's Avatar
Last night i was on the way over to a friends house and i decided to run my car real hard from a stop light. It was actually the first time I floored it since i put my new clutch in about 600 miles ago. Anyways, I had the car at about 5800 rpm's for a few second and launched from the light like normal. When I let off, the car started to run pretty rough and there was a really weird clicking noise coming from the front of the motor. I got out and checked the motor to notice any simple problems like plug problem, egr tube, vacuum leak and there was nothing that i could notice. The exhaust note has completely changed and i am not really sure what else to check other than internals. I have heard people have similar problems with broken valvetrain components and i always seems to assume the worst first. I checked the exhaust as well and it all seems to be tightly connected. Any ideas on what could be the cause of a symptom like this. Thanks
Old Mar 5, 2008 | 07:05 AM
oh i forgot to say my car is a 1993 z28 m6 with minor bolt ons and no internal work.
Old Mar 5, 2008 | 07:20 AM
Try to isolate the noise. Could be valvetrain, but might be the opti rotor letting loose.
Old Mar 5, 2008 | 01:56 PM
I checked the oil pressure and fuel pressure and they are both normal, it vibrates and clicks at all rpms whether sitting still or driving the car. It gets a pretty aggressive vibration at certain rpms, but the whole car shakes no matter where you are in the rpm band. What key things should i check first before i rip into the valve covers?
Old Mar 5, 2008 | 02:50 PM
BUBBA's Avatar
pull the covers.
Old Mar 5, 2008 | 03:05 PM
dangalla's Avatar
Originally Posted by BUBBA
pull the covers.
yup sounds like a 'train problem
and i would not run it any more until you do, get the covers off and if nothing is obvious fire it up then and look around
Old Mar 5, 2008 | 03:18 PM
Pro_built7's Avatar
my bet is valvetrain, somethings broken/loose,
Old Mar 5, 2008 | 03:21 PM
thebufenator's Avatar
Could be the timing chain aswell.
Mine started acting like you said......the timing gear sheered its bolts off of the cam....destroyed the motor.....
DirtyDaveW
Dec 1, 2016 05:37 PM
HuJass
Aug 29, 2002 02:30 AM
HuJass
Aug 27, 2002 09:58 PM
HuJass
Aug 27, 2002 09:53 PM
HuJass
Jun 27, 2002 11:04 PM
