emissions results..FAIL!
Old Aug 13, 2008 | 08:30 PM
Austin_78@msn.com's Avatar
so i went and got my z emissioned and here is what the results looked like....
HC GPM-9.9732 limit-1.500 FAIL
CO GPM-77.6806 limit-15.0000 FAIL
NOx GPM-0.0365 limit-3.5000 PASS!
I reall have no idea where to begin. .
Ive replaced just about everything... o2's, map, fuel press. reg., 26#injectors,
knock sensor, IAC, pcm, etc.
Any help is apreciated!!
Old Aug 13, 2008 | 08:43 PM
94arcticwhiteM6's Avatar
it looks like you are either dumping fuel or your cat is dead or possibly hollowed out?
i would lean more toward a cat issue with the list of other stuff you have replaced.
Old Aug 13, 2008 | 09:55 PM
High HC and CO, combined with very low NOx would indicate that it is running excessively rich.
Old Aug 13, 2008 | 10:34 PM
yes very rich....
anything i can do to help this?
EDIT: also, would smoke from startup be a sign of a dead cat?
Old Aug 14, 2008 | 07:04 PM
Red-LT1's Avatar
When was the last time you checked your plug wires? O2 sensors?
Old Aug 16, 2008 | 12:09 AM
few months ago.
just heard from the shop and turnd out how i was using no stat made it pretty bad.
cylinder 4 spark plugs gap was bent so that explains the fuel dump...and the left o2 sensor is bad!!!
so i get to actually have 8 cylinders now come monday!
sleeperZ96BT
Sep 9, 2015 08:28 AM
sherwinZ28
11
Aug 15, 2015 05:38 PM
FredM
Exhaust System
Feb 18, 2015 05:37 AM
jgeorger
Oct 24, 2002 09:31 PM
jgeorger
New England Area
15
Sep 8, 2002 09:50 AM
