Emissions or no emissions
Hey dudes, im looking to get some headers in a few days thanks to some Xmas money..
I want to go with Pacesetter LTs and ORY
Now question is.. Should i get emission headers or non emission..?
Also, if you guys can list what else you bought to go with your LT install that would be great
Thank you
Thank you
Re: Emissions or no emissions
I am about to get some for my car, and I am buying them with emissions fittings and am going to cap the fittings off. That way, if I need the emissions equipment later on down the road, it's there, and I just un-cap it all and hook it up. Last header install I did on a car I ordered a set of stage 8 locking header bolts, that way the header bolts didn't come loose and cause an exhaust leak.
If you go with the pacesetters your going to need to cut your catback and weld or clamp the y-pipe to it, i would recomend welding but if you can't, get one of those wide stainless band clamps, they work pretty well.
Another thing to get with the install is stock exhaust manifold gaskets. I know that the headers will probably come with gaskets, but I've found that a lot of them leak eventually. The only one that has stood the test of time, is the stock gaskets. You may have to cut them a little to fit, but it's worth it when you consider the time it takes to change a gasket after it starts leaking.
Benji
Benji
Yeah they prob won't like the 306. Are you still at 194k or have you hit 200 yet?
i think i'm around 196k now, not exactly sure, damn close, stock shortblock and the heads have never been off.
The cam is good from what i remember driving it for a week, haha, my friend put together a pretty good tune for it and there isn't really any cam surge. If its tuned well i would say its perfectly fine for a daily driver, the low end is simular to the stock cam i would say but she really wakes up around 3-4k and pulls strong well past 6k where the stocker has died off well before. when i put it away i could spin the tires in 2nd at over 60 mph, it was only 20 degrees though, lol. Looking for mid/low 12's this spring on a close to 200k mile mill, it doesn't burn any oil and the compression is strong so i'm even tempted to spray it
wow, thats very very impressive running that big of a cam on a 200k mile engine, im afraid to put something like that in my car that only has 83.
in reply to the original question, i bought Pacesetter LTs with emissions hookups, not sure if im going to run emissions or not myself, but i definitely will not be deleting them unless they delete themselves (break).
Thank you
Thank you
Originally Posted by zx1216
well i just got the cam in before thanksgiving and i had to put it away because of the snow but i prolly have about 500 miles on it and so far so good to 7k multiple times
Originally Posted by turbo_Z
I wouldnt run a 200k mile STOCK motor to 7k rpm unless I was trying to intentially break something and yours has a fresh cam swap... hope your luck continues but youre really pushin it. You could tear it down now before the bearings give out and save yourself a lot of machining costs.
sleeperZ96BT
Sep 9, 2015 08:28 AM
jgeorger
Oct 24, 2002 09:31 PM
