Emissions legal camshafts.
Old Feb 2, 2005 | 05:56 PM
  #16
DiabloGT's Avatar
Re: Emissions legal camshafts.
so do you think it will be legal in the smog emission in MA?
Old Feb 3, 2005 | 03:55 AM
  #17
onebadponcho's Avatar
Emissions legal cams, hmmm.....
-Crane makes one that has a CARB/EO#; not sure about the part number, but the specs are something like:
218/218 dur@.050, 280/280 adv. duration, 116LSA, .498 lift w/1.5 rockers
-TPIS makes the ZZ9; also has a CARB/EO#:
212/226 dur@.050, 282/286 adv. duration, 112LSA, .483/.520 lift w/1.5 rockers.
.....and there's probably a lot of other cams out there similar in size or smaller that would pass a sniffer without much problem.....it's just that the makers of those cams didn't go through the expense and trouble of testing these cams in order to get the CARB/EO#. Also, I'm sure others pass emissions with bigger cams than these, but it takes some creative tuning to do that. HTH.
Old Feb 3, 2005 | 05:23 AM
  #18
anaik's Avatar
I stand corrected, there are cams with EO#'s. Although TPIS states their combo ZZ9 with the Stage 2 heads is an emission legal engine.
Old Feb 3, 2005 | 12:30 PM
  #19
JB94's Avatar
Thanks for all the excellent information.I have read a little about the ZZ9 and seen it installed in an older magzine article and they reported increases of 40-45 horsepower with the cam alone.Though it seems the majority of people are running the hot cam I think I will go with the ZZ9.How about some feedback from anyone out there running this camshaft.
Old Feb 3, 2005 | 02:34 PM
  #20
FlyboyZ28's Avatar
I heard that if you unplug some fuel injectors it will pass. Is this true.
Old Feb 3, 2005 | 03:13 PM
  #21
CamaroSS30thAnn's Avatar
what are the specs for the GM 846 how is it comparable to the cc305 and which is better
Old Feb 4, 2005 | 03:59 AM
  #22
Check the pricing on the ZZ9 and the Hotcam. The ZZ9 costs about twice as much as the Hotcam, which is why a lot of people go with the Hotcam.
Old Feb 4, 2005 | 11:40 AM
  #23
JB94's Avatar
So hypothetically speaking if cost was not a determining factor on which one to run ,is the ZZ9 the better of the two for a daily driver that has to stay emmisions compliant?
sleeperZ96BT
Sep 9, 2015 08:28 AM
WPHIG2
Aug 27, 2015 06:37 AM
CARiD
Exhaust System
Aug 3, 2015 05:10 AM
Collinjacobfowl
Jul 30, 2015 09:35 PM
asilomar244
Jul 12, 2015 05:53 AM
