emissions
Old Feb 3, 2008 | 01:05 PM
z28camaro1090's Avatar
emissions
could a leak from the headers cause low idle emissions to double what is allowed in the state of delaware? 220 is allowed mine was 456
Old Feb 3, 2008 | 02:00 PM
Dave1980's Avatar
A header leak before the o2 sensors is going to make the computer think it is running lean on that side. Then it will try to compensate on that side by richening the mixture to correct. It will increase emissions not only at idle, but other areas. It is not good for MPG also.
Old Feb 3, 2008 | 03:05 PM
What component of emissions is 456..... CO, HC or NOx? Without that info, its impossible to answer your question accurately.
Old Feb 3, 2008 | 03:22 PM
96WS6TA's Avatar
Must be HC's....456 Nx is not that high and CO is measued in percent (ie. more than 1% is high. 456 HC's is too high however.
Old Feb 3, 2008 | 05:35 PM
it was teh HC(PPM) on the low side the max allowed was 220 and it was 456.. all other emissions passed..
Old Feb 4, 2008 | 07:57 AM
How close was the CO to the pass/fail limit? How close was the NOx to the pass/fail limit?
Running rich would cause high HC and high CO. Leaking injector(s) would cause only HC to be high. Faulty cat might cause all three to be high.
Old Feb 4, 2008 | 09:57 AM
umm the
hc's Low 456 allowed 220,
hc high 178 allowed 220
co low 1.19 allowed 1.20
co high 1.18 allowed 1.20
these were the only emissions that they took. so the only one that failed was the hc low with alittle more then double the allowed. which confuses me. I have no clue why it would almost double the allowed, but nothing else be failing
Old Feb 4, 2008 | 10:22 AM
Sounds like its running rich. This can be caused by a "false" lean condition... leading causes are misfires and exhaust leaks before the O2 sensors, as noted in the first response to your post.
Old Feb 4, 2008 | 02:46 PM
i thought that cold be contributing to the problems the other thing. i was wondering about is i hear a ticking noise like from where the rockers are. a mechanic said its sounds tired lol i just had to laugh. because im pretty sure its a loose rocker.. i had the covers off about a month ago and realized alot of the rockers had alot of play side to side in them. I am bringing this up because someone said a lifter could be floating out due to this and causing this too.
Old Feb 4, 2008 | 04:21 PM
LSWHO's Avatar
Makes me happy AZ just checks your computer.
sleeperZ96BT
Sep 9, 2015 08:28 AM
sherwinZ28
11
Aug 15, 2015 05:38 PM
FredM
Exhaust System
Feb 18, 2015 05:37 AM
jgeorger
Oct 24, 2002 09:31 PM
jgeorger
New England Area
15
Sep 8, 2002 09:50 AM
