Emission problem...
Old Aug 11, 2004 | 06:51 PM
Purplemaroz28's Avatar
Emission problem...
I want to start my project but i have a few questions with the emissipons ...Can i pass with LE heads and cam...take in mind that im gonna awitch all my boltons back to stock before i smog ...and im gonna probaly get a higher themro to try to pass....im trying to decide if i should go with a heads and a cam setup or just do good old forced induction , from wat i read id rather do heads/cam...
btw im not gonna go crazy on the cam ..itll probaly be a mild cam...thanks gyuys for any knowledge u can bestow upon me..
later
steven
Old Aug 11, 2004 | 08:10 PM
Mystic95Z's Avatar
Re: Emission problem...
You should be able to pass with ported heads and a hot cam'ish cam in cali. I've even heard of peeps passing cali emissions with a CC306 and a good emissions tune.
-Tony
Old Aug 11, 2004 | 08:16 PM
Thanks for the confidence booster mystic...i think im gonna go for that then...cross my fingers and knock on some wood
later steven
Old Aug 11, 2004 | 08:20 PM
ARRFormula's Avatar
I got some "lightly" ported heads, hotcam and 1.6 RR's...with edlebrock headers, Borla and stock cat.
With a stock tune...I passed a couple years ago.
I am due up for another smog this year...before October. Right now, I dont know if I will pass. I'm gonna get a tune from madz28.com or pcmforless with new 02's.
I hope I pass...I'm starting to get worried about the smog ***** here
Old Aug 11, 2004 | 08:28 PM
RE AND CHERYL's Avatar
-Tony
I wouldn't put all your nuts in that basket. I have never heard of a person that got a CC306 through the sniffer emissions test (please speak up persons that have). You will need a damn good tune with a CC305 to get through, and the 306 is quite a bit bigger. The other problem will be that it will be obvious to anyone with ears that there is an after market cam installed (I hear that is a no-no in Cali without paper work to prove carb exemption).
I would stick with something the size of a Hot cam or smaller. Loyds heads are awsome but he states that all three of his cam won't pass emissions. Might want to talk to Joe Overton and see if he can grind you up something special.
Old Aug 11, 2004 | 08:40 PM
Mystic95Z's Avatar
RE & ... I've been around here a while, and have read here where some have passed cali emissions with a CC306 & good tune. It's definatly not a guaranteed, but has been done before that all I'm saying. We have the IM-240 test here in So. IN and I passed with a few tweaks with numbers way better than I did with a stock motor with the mods in sig except for LTCC.
-Tony
sleeperZ96BT
Sep 9, 2015 08:28 AM
sherwinZ28
11
Aug 15, 2015 05:38 PM
FredM
Exhaust System
Feb 18, 2015 05:37 AM
InfernalVortex
Jan 17, 2015 09:35 AM
jgeorger
New England Area
15
Sep 8, 2002 09:50 AM
