Electronic Speedometer Converter
Old Jul 9, 2003 | 12:58 PM
93ZM6Tally's Avatar
I know that SLP makes an electronic speedometer conversion box to compensate for gear changes, (I'm running a Moser 12 bolt with 4.11 ratio), but I can't find the effin part number. SLP's web site is the worst. BTW seen lots of posts that incorrectly state that a 93 M6 can be corrected via the PCM - this is incorrect. M6 have an electronic speedo that is not routed via chip. Can only be corrected with a converter box - WHICH I CANT FIND?
Thanks.
Old Jul 9, 2003 | 02:01 PM
You might also want to consider this item from Dakota Digital . Probably cheaper than anything SLP sells.
Old Jul 9, 2003 | 02:22 PM
93ZM6Tally's Avatar
Fred, as usual you are the man.
Old Jul 9, 2003 | 05:10 PM
Z28BICOL's Avatar
SLP Speedometer box.
Do not use the SLP speedo box. It will correct the gear/tire speed, but you will lose or have problem with your cruise control. That's probably why they stop making them. They won't even help me fix it.
zFrank
Aug 12, 2015 03:46 AM
nosliw
Apr 27, 2015 04:01 PM
NewsBot
Apr 20, 2015 03:00 PM
Jul 4, 2005 05:00 PM
