Electrical problem
Old Jul 5, 2011 | 01:31 PM
Jeffb3362's Avatar
Angry Electrical problem
I have a 95 Z that has a huge electrical problem. Code reader indicated a coolant fan circuit issue along with EGR circuit, EVAP circuit, and reverse lockout circuit. The 10amp fan fuse blows when i turn the car on. The relays are good. I looked up in the shop manual and all these ciruits are tied into this one fuse. Any suggestions would be much appreciated
Old Jul 5, 2011 | 02:25 PM
OBE1 95Z28's Avatar
Re: Electrical problem
I suspect you have a short to ground in the wiring harness(es) leading to these sensors/fans causing the fuse to blow. Check all the wiring to look for something worn through shorting to the chassis. You can unplug all the the sensors/fans then turn the key on and see if the fuse blows. If it blows it confirms it's in the harness and not a shorted sensor.
liamcg97
Nov 25, 2019 05:55 PM
eanhl2004
Apr 4, 2015 12:01 PM
robcarnut
Mar 20, 2015 03:40 PM
BMX Dad
Jan 23, 2015 07:00 PM
97z28k&N
Jan 9, 2015 04:58 AM
