electric waterpump does not work and fans do not turn on
Old Aug 15, 2005 | 02:12 PM
96KillaZ's Avatar
What would cause this. All of a sudden one day I turned on my car and they just stoped working. Also my check engine light turned on but when I go to scan it, the code reader dosent even turn on. I know the code reader is good because I used it on my other car. Please help me, I wanna order a new waterpump but I just wanna make sure that that's the problem... Thank in advance for any help.
Old Aug 15, 2005 | 02:14 PM
blackztpi's Avatar
Re: electric waterpump does not work and fans do not turn on
well, what did u wire your waterpump to? if you wired it to your fans, you could have blown a fuse or something. check into that. relook all your fuses and wiring for both
Old Aug 15, 2005 | 02:47 PM
ScreamnChicken's Avatar
Did you install a relay for the WP when you installed it? If not, you prolly blew the fuse for the fans and wp.
Old Aug 15, 2005 | 03:01 PM
transamdude95's Avatar
sounds to me like you blew a fuse... i use a 20 amp inline fuse for my e-w/p. If the fuse is blown(and you used 20 amp or higher), take off your water pump and make sure the impeller isn't coming off... happened to me with my CSR. The impeller worked itself loose and would seize and blow the fuse.
Old Aug 15, 2005 | 03:42 PM
96KillaZ's Avatar
Is the fuse on the electric water pump? where would the fuse for the pump and fans be? the car came with the electric waterpump
Old Aug 15, 2005 | 04:17 PM
follow the wiring, it should be between the pump and the relay.
liamcg97
Nov 25, 2019 05:55 PM
squarehead
Jan 15, 2015 07:02 PM
97z28k&N
Jan 9, 2015 04:58 AM
IgorT.455/406
Feb 1, 2005 06:18 AM
