electric water pumps
Old Jan 8, 2004 | 03:16 PM
ABA383's Avatar
Can anyone tell me what gains can be expected with an electric water pump on an LT1...any dyno results or track ETs would be appreciated...thanks
--Alan
Old Jan 8, 2004 | 03:36 PM
GREGG 97Z's Avatar
Most claims I've heard are between 5-10rwhp, I really doubt anyone has ever done a dyno comparison before and and after installing one with no other mods done at the same time but maybe someone has. I used the CSI when I did my cam, I'm sure it helps free up some HP especially at high rpm but it's hard to know exactly how much.
Old Jan 8, 2004 | 04:04 PM
ABA383's Avatar
Thanks for the info...Is the electric pump ok for street use? My car sees about 5000 miles a year,,,I was concerned about seal life and any cooling probs, if any, associated with under drive pulleys...
Old Jan 8, 2004 | 04:26 PM
GREGG 97Z's Avatar
They are fine for street use, temps stayed the same with mine even sitting in traffic in the summer it didn't go over 180 degrees. That is with the 160 t-stat and reprogramming to lower the fan settings. When they go out on you the temps will shoot up pretty quick though, I have an indicator light installed to tell me when it's on as a precaution. I think the CSI and others are rated for 2000 hours of service life. Having an underdrive pulley has no effect on the stock pump or electric pump unless you are having charging problems I guess. I put just under 5k on my car last year since installing it and I've got a 25% underdrive pulley and it's worked great so far.
Old Jan 8, 2004 | 04:50 PM
joeSS97's Avatar
Look here. www.projecttransam.comGo to install guide-cooling system-Meziere wp-at the bottom.
Old Jan 8, 2004 | 06:35 PM
ABA383's Avatar
Thanks "JoeSS97" great site...10 rwhp ain't too shabby...makes my 11.70s go to 11.60s....Thanks again...
--Alan
Old Jan 8, 2004 | 08:09 PM
"White Knight"'s Avatar
You beat me to it JOE. I was going to post that link. . Plan on swaping mine out when summer comes.
Great for street use expecially when you want to get her all to the rear wheels
Electric water pumps should have been stock!!!!!!!!!
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Stay Puft
Apr 20, 2015 06:24 PM
Queens94z28
Dec 20, 2014 09:11 PM
Zone
Jul 29, 2002 07:43 PM
