Can I shave a full second off with this?
Old Jan 7, 2004 | 03:51 PM
showtime89's Avatar
You think I could shave a full second off my 1/4 mile time with this mod only? Stage 1.
http://www.cmotorsports.com/engine/l...heads-cam.html
My current mods are listed below. I believe the price was right around $2000.
Of course I would have programming done too.
I know, I know, I need traction, but I am talking with what I have now. Mods are listed below.
Old Jan 7, 2004 | 04:20 PM
1.8ttolt1's Avatar
that should be pretty easy depending on the cam you get. since you currently run a 13.5, dropping down to a mid to low 12.xx should be no problem.
Old Jan 7, 2004 | 06:03 PM
solid95z's Avatar
You should be able to pick up well over a secnd in your 1/4 time. Actually you car should be in the high 12 range like it is now. Did you run that 13.5x on street tires or et streets, that will make a difference?
Scott
Old Jan 7, 2004 | 07:12 PM
showtime89's Avatar
Street tires @ 10psi
Old Jan 7, 2004 | 07:32 PM
solid95z's Avatar
Originally posted by showtime89
Street tires.
awwwww...make mo betta sense now
If you plan on running on street tires you may be able to knock off a full sec depending on what cam you get. But with slicks, HELL YEEEAAHHHH!!!
Old Jan 8, 2004 | 08:11 PM
showtime89's Avatar
So if in fact it is $2000 does it seem like a good deal?
PCLZ28
Dec 24, 2015 05:19 PM
Apr 16, 2015 09:57 AM
Jan 23, 2015 01:13 PM
dreamer1q
Sep 12, 2002 01:00 PM
slothgrant
Aug 22, 2002 03:01 PM
