Electric Water Pump
Old Mar 13, 2008 | 12:56 PM
  #16
caldercay's Avatar
Originally Posted by 96' Formula WS6
[snipped]
caldercay thanks for the pick, it also helps that you got the exact same w/p as i have just ordered. how do you like your decision.
I certainly dont regret it and I will continue to use electrics, both for the
HP gains and the ease of servicing.
Old Mar 13, 2008 | 08:16 PM
  #17
klrz28's Avatar
which way is the impeller suppose to turn looking at it?
Old Mar 14, 2008 | 06:51 AM
  #18
Ken95Z28's Avatar
Here is a write up I did along time ago.
CSI Water Pump Install
Old Mar 17, 2008 | 08:41 PM
  #19
96' Formula WS6's Avatar
OK guys well I got it all done and its working great for now. But quick question I test ran the motor when I got it but not after it was installed on the pump but when I turn it on with the car off it makes kind of like a scratching sound. Almost like a metal on metal but not that bad. Is that what they all sound like or is mine messed up. What does your pump sound like. Its a mez pump
Old May 17, 2009 | 03:27 PM
  #20
merim123's Avatar
Originally Posted by Steve in Seattle
tip: bypassing the water pump relay once it's installed can run the pump to speed refilling of the radiator.
this is a interesting idea. where is the water pump relay. I need to fill mine up now...
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Stay Puft
Apr 20, 2015 06:24 PM
Queens94z28
Dec 20, 2014 09:11 PM
Zone
Jul 29, 2002 07:43 PM
