electric water pump
Re: electric water pump
You have to have the impeller pressed out and bang in a new freeze plug in it's place. After that, use a relay harness and wire in the pump. OH yeah, you'll also have to file out reliefs for the pump to fit in the hole where the pump cover sits so the pump will fit in there.
