electric water pump????
Old Sep 27, 2004 | 06:02 PM
skibbe_96z's Avatar
Is anyone running an electric water pump? I will be down in that area anyways when I do my cam swap and everything so i was looking into a water pump. My car only has 40k so i really dont need one...i was jsut curious about the electric one. Does it help you any. Do they last...i have heard that these die quickly. also...what belt size would I need if I went to that set-up. Thanks.
Old Sep 27, 2004 | 06:18 PM
Mtrhds94Z's Avatar
Re: electric water pump????
Belt size doesn't change with an electric water pump on an LT1[it's driven off the cam thru the timing cover]
You get a Meziere or CSI pump for LT1, then bash out the impeller and bearing/seal in the stock housing, take the front plate off it, then bolt the electric pump to the housing..
Use a relay in the power source..
Old Sep 27, 2004 | 06:22 PM
skibbe_96z's Avatar
so does this set-up free up some horsepower? or is it a lost cause and i should keep the original one on?
Old Sep 27, 2004 | 06:38 PM
ibanez6rg's Avatar
It will free up minimal hp. I'm using a CSI EWP, and it's working fine.
Old Sep 27, 2004 | 09:15 PM
5.7LT1Formula's Avatar
Painless has the wiring you want for like 30 bucks that has everything inline so you do not fry your pump or anything else.
Old Sep 27, 2004 | 09:18 PM
Cwynn's Avatar
Dyno proven 10whp with the electric waterpump plus your car will run cooler.
Old Sep 27, 2004 | 09:40 PM
dmoor88's Avatar
No modification of the housing is needed with the Meziere. It is with the CSI.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Stay Puft
Apr 20, 2015 06:24 PM
Queens94z28
Dec 20, 2014 09:11 PM
Zone
Jul 29, 2002 07:43 PM
