elec water pump warning light
Old Jan 4, 2005 | 01:05 PM
  #16
camaroKid223's Avatar
Re: elec water pump warning light
slopokrodrigez thanks for all this help your really seem to know your stuff! im not sure if i understand how the jet fan switch can be connected to this? (i thought that that would just connect to the fan to turn the fans on?)also it doesnt have the lt1 listed will it still work?
  #17
Serene's Avatar
Originally Posted by turbo_Z
if you really want some security you could wire in the ignition thru the waterpump that way if the pump dies it will shut the car off with it.
oh ya that sounds like an extremely safe choice. Nice recommendation.
Old Jan 4, 2005 | 01:06 PM
  #18
slopokrodrigez's Avatar
You don't need to worry about that. The only thing you need is the proper thread size and temperature rating. If you look at my drawing you will see the single wire from the temperature switch goes to one side of the light bulb. On the other side of the bulb you connect +12 Volts. When the switch closes at 195 degrees (or what ever temperature you choose) the light will come on.
In addition I added a relay that will light the bulb when ever you have the water pump turned off. In that way, if the light is on either the pump is turned off or the temp is too high.
Don't let that drawing confuse you. The #2 relay is connected with the sensor and the bulb. It's a snap.
Dave
Old Jan 4, 2005 | 01:12 PM
  #19
Guest47904's Avatar
Guest
Yeah not only that but he obviously doesn't know how big and bright the light on the Autometer is. You could land planes with that thing
PT Barnum said "There's one born every minute".
Old Jan 4, 2005 | 01:15 PM
  #20
so i would just use two of the wires from the jet wiring harness?
Old Jan 4, 2005 | 01:19 PM
  #21
Nope, you only need one that comes with the switch. The kit you can buy will only have a butt splice.
Got to Summit and look at that picture for the kit I listed. If you want that kit be sure it has the right thread size for the block. I think it does. If not, get the one for the LT1. The only difference is higher price.
Old Jan 4, 2005 | 01:26 PM
  #22
turbo_Z's Avatar
Beats blowing a head gasket and possibly ruining a nice motor.
Old Jan 4, 2005 | 01:33 PM
  #23
Serene's Avatar
um. if the water pump fails, the temperature of the motor is not going to instantly go to 500 degrees. A light/buzzer would give you plenty of time to pull the car to the side of the road.
Shut the motor off, brakes become hard to use depending on how long (how fast you are going) it takes to empty the vacuum reserve in the booster, steering becomes difficult, no power to move the car if you had to get out of someones way, etc
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
squarehead
Jan 15, 2015 07:02 PM
pologreen97z
Dec 2, 2014 10:42 AM
