elec water pump warning light
Re: elec water pump warning light
slopokrodrigez thanks for all this help your really seem to know your stuff! im not sure if i understand how the jet fan switch can be connected to this? (i thought that that would just connect to the fan to turn the fans on?)also it doesnt have the lt1 listed will it still work?
Originally Posted by turbo_Z
if you really want some security you could wire in the ignition thru the waterpump that way if the pump dies it will shut the car off with it.
In addition I added a relay that will light the bulb when ever you have the water pump turned off. In that way, if the light is on either the pump is turned off or the temp is too high.
Don't let that drawing confuse you. The #2 relay is connected with the sensor and the bulb. It's a snap.
Dave
Originally Posted by Serene
oh ya that sounds like an extremely safe choice. Nice recommendation.
PT Barnum said "There's one born every minute".
so i would just use two of the wires from the jet wiring harness?
Got to Summit and look at that picture for the kit I listed. If you want that kit be sure it has the right thread size for the block. I think it does. If not, get the one for the LT1. The only difference is higher price.
Beats blowing a head gasket and possibly ruining a nice motor.
Shut the motor off, brakes become hard to use depending on how long (how fast you are going) it takes to empty the vacuum reserve in the booster, steering becomes difficult, no power to move the car if you had to get out of someones way, etc
squarehead
Jan 15, 2015 07:02 PM
