EGR valve
Old Sep 29, 2006 | 09:09 AM
cleangene's Avatar
EGR valve
what do I do about the EGR when I put on my Lts that has no EGR hook up
Old Sep 29, 2006 | 09:19 AM
95LT1conv's Avatar
Re: EGR valve
you need to buy a set of blockoff plates. check ebay they are usually on there pretty cheap
Old Sep 29, 2006 | 10:02 AM
Re: EGR valve
And then (depending on theyear of your car), you may need to have the DTC codes programmed out. OBD-I 93-95 usually don't set a code for a missing EGR, but it is possible you will get a code for low/no flow. In OBD-II cars (96-97) you are 99% sure of getting a code for low/no flow and it needs to be programmed out of the PCM.
Then there's the code for the EGR vacuum solenoid. If you delete that solenoid, there's another code. Can be programmed out, or you can put a resistor in the electrical connector.
Old Sep 29, 2006 | 10:39 AM
97bowtie's Avatar
Re: EGR valve
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMESO%3AIT
Old Sep 29, 2006 | 01:05 PM
cleangene's Avatar
Re: EGR valve
thanks the answers...
14
Aug 11, 2015 12:03 PM
Jlo
Jul 29, 2015 03:52 PM
RX Speed Works
Jul 24, 2015 02:25 PM
HectorM52
Parts Wanted
Jul 19, 2015 08:55 PM
Dark Zeiro
Jul 19, 2015 08:25 AM
