EGR and Smog pump delete
Old Jul 5, 2005 | 05:28 PM
96trans am's Avatar
Does anyone know the part numbers of what i will need when taking out the EGR and Smog Pump. Cant remember if i need anything for the smog pump but i know there is some type of plug that i need from GM when removing the EGR. Thanks for the help.
Old Jul 5, 2005 | 05:42 PM
69vette's Avatar
Re: EGR and Smog pump delete
the egr block offs can be bought of of ebay. there is a guy selling them with free gaskets. check them out
Old Jul 5, 2005 | 06:40 PM
Will84's Avatar
Those free gaskets you get, blow ***... but they're good enough for what they are meant for. I used the Felpro ones that came with my gasket set. That's all you need though. Like 69vette said... do a search on ebay for LT1 EGR blockoffs. Be sure to get the 3 piece kit while you're at it.
Old Jul 5, 2005 | 06:47 PM
96trans am's Avatar
Well i dont need em for the headers, just the intake. I was going to order the block off plate and the gasket off of gmpartsdirect.com. While im at it what kinda gaskets you guys using when doing heads/cam. Also what bolts? I seen they have a heads/cam gasket set for like 2 something on thunderracing. Also do you guys on replace the head bolts?
Old Jul 5, 2005 | 07:22 PM
Will84's Avatar
I used Felpro gaskets and ARP bolts. It is recommended to replace the bolts... but... on my previous rebuild I torqued the stock bolts back down and never had a problem over the next 40k.
Old Jul 5, 2005 | 07:38 PM
96trans am's Avatar
Its only necessary to replace head bolts?... What about intake bolts?
Old Jul 5, 2005 | 08:47 PM
Bawls's Avatar
Stock head bolts shouldn't be reused, buy a set of ARP head bolts. When I did mine, I reused my intake bolts, ARP head bolts, and stock LT1 gaskets all around, except the header gasket, used felpro 1406 for that.
Old Jul 5, 2005 | 08:48 PM
Bawls's Avatar
Also you'll need the first kit from SJM for your egr blockoff.
http://www.sjmmanufacturing.com/cam_eng_lt1.html
Old Jul 5, 2005 | 08:54 PM
96trans am's Avatar
Kool that the info i was looking for
You guys by any chance also know when converting to an electric waterpump what you need to put where the mechanical drive was in the waterpump Is this some type of blockoff?
Old Jul 5, 2005 | 09:00 PM
Bawls's Avatar
The pump will come with a freeze plug. Just leave the cam drive in there, or else you'll have to remove a lot more ****.
Plug the w/p housing where the cam drive went through with the supplied freeze plug.
HarleyZ28
Oct 5, 2015 06:23 AM
edman
Mar 13, 2015 09:39 PM
alphaauto
Jan 23, 2015 07:42 AM
cmdeshon
Dec 27, 2014 10:06 AM
Timberwolf
Aug 9, 2002 11:24 AM
