EGR replacement for Amatuer
Old Aug 20, 2006 | 09:53 PM
SteveSS's Avatar
I am getting a code for the EGR valve on my 97SS. I know where it is and what bolts hold it on but I can't really reach it. Can anybody give me some step by step instructions to get back there? What do I need to remove first?
Old Aug 20, 2006 | 10:30 PM
Heatmaker's Avatar
Advanced Member
Re: EGR replacement for Amatuer
It's very simple. All you need is a 13mm wrench. First thing you do is pull the vacuum hose off the top of it, then use the 13mm wrench and remove the 2 nuts holding it down. It takes patiences because the area is so tight back there. Moving the fuel rail to the side, and pushing away the wires should help some. Also don't forget the EGR gasket.
Old Aug 20, 2006 | 10:48 PM
95z28_m6's Avatar
When i changed my egr i waited until my motor was cool, stood directly in front of the car, and streatched out over the top of my motor. This was the easiest way i found to reach it.
Old Aug 21, 2006 | 12:17 AM
Geardrive63's Avatar
if you wrap your arm around just infront of the PCM and run your arm along the firewall there's plenty of clearance for your arm and the 13mm wratchet. that's how i did mine, just did mine today actually.
Old Aug 21, 2006 | 12:39 AM
Josh'95Z28conv's Avatar
Easiest way to fix the code would be to program it out And then maybe clamp the egr tube shut to prevent any gasses from passing through (incase the valve is stuck open). Then later put plates on the back of the intake.
Who needs a stinking egr valve anyway
Old Aug 21, 2006 | 08:42 AM
The nuts on the EGR valve are not metric. They are 1/2".
Old Aug 26, 2006 | 02:55 AM
Heatmaker's Avatar
Advanced Member
Didn't stop my wrench from getting the job done.
Old Aug 26, 2006 | 02:12 PM
SteveSS's Avatar
Would this malfunction give a big loss in power? I notice I don't chirp in second anymore.
Old Aug 26, 2006 | 05:13 PM
00JoeZ28's Avatar
I just deleted my egr on my '97 SS today and it too through a code out thier. How does one program it out?
Old Aug 26, 2006 | 05:30 PM
Heatmaker's Avatar
Advanced Member
I think it has to be programmed out.
Old Aug 26, 2006 | 06:51 PM
I use tunercat. You can use either that or lt1 edit, or find a shop that uses one of those programs and have them take care of it.
Old Aug 26, 2006 | 08:40 PM
00JoeZ28's Avatar
How much does something like that cost (tunercat)? Do you know what the average cost for a shop to do it is?
edman
Mar 13, 2015 09:39 PM
97SSdude
Dec 31, 2014 07:43 PM
jocamino
Dec 29, 2014 10:15 PM
thenewkid
Nov 18, 2014 12:57 PM
CobraEatr
Jul 29, 2002 11:46 AM
