egr replace 1997 z28
Old Nov 13, 2010 | 02:30 PM
pauliesz's Avatar
I have a 1997 z28 need to replace egr have one nut out but cant get to other one. egr is on back of manifold lines are in the way for other side.any suggestions? New to site thanks!
Old Nov 13, 2010 | 09:31 PM
Re: egr replace 1997 z28
All you have to do is get enough of a wrench on it to break it loose. The nut should spin right off, easily. Put a blanket over the engine and lay across it like Superman and feel your way around. Try a different combination of tools, if needed. You can do it.
Old Nov 14, 2010 | 01:21 PM
mudbone's Avatar
I used one of those Gear Wrench ratcheting wrenches to get mine off. I slipped the box end on the nut and gave 'er a tug. It is a bit tight getting to the one on the driver's side. FYI, I re-tightened the nuts twice after a couple of trips to give the gasket some time to seat.
ScottZ
Mar 3, 2004 01:34 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
30thZ286speed
Aug 3, 2002 04:54 AM
