cc501
Old Nov 14, 2010 | 08:19 AM
undecidedfbody's Avatar
cc501
how good is it
Old Nov 14, 2010 | 08:51 AM
Re: cc501
Depends what your intended use is. Its small, probably can be tuned to pass emissions easilly. Comp recommends it for unmodified engines, 1500-5200rpm. Here's the Comp Cams info:
http://www.compcams.com/Company/CC/c...csid=1105&sb=2
Old Nov 14, 2010 | 10:40 AM
Re: cc501
would 1.6 roller rockers help this thing cause this motor got all of things done to it its in my signature
Old Nov 14, 2010 | 12:01 PM
Re: cc501
The cam is really small.... smaller than the much maligned LT4 HOT cam. 1.6X RR's will bump the lift up to 0.520 I / 0.528 E.
What's been done to the heads, other than the valve job? What do they flow at lifts above 0.500"? The mods list you post isn't really indicating its "got a lot of things done to it". The forged stuff is nice, but it doesn't make power. The Edelbrock intake manifold is a dog. There's nothing there that requires a 58mm TB.
If you have more done to it than what's in your signature, list it. What's the compression ratio? Did you build it - so you know whats really inside - or did you buy it already built?
Old Nov 14, 2010 | 08:12 PM
96capricemgr's Avatar
Re: cc501
Be aware the Comp rpm ranges are WAY too low. I would expect to take that cam to 6000rpm. If you want a XE comp cam at least look at the 502 if not the 503.
Parts Wanted
Apr 27, 2013 07:49 AM
Pig Pen
Feb 28, 2012 02:28 PM
b25
Oct 26, 2011 08:55 AM
