EGR removal
Old Aug 22, 2005 | 12:03 AM
ZyberMunster's Avatar
EGR removal
I've already got a set of block-off plates for my LT1, but it looks like a real nightmare removing the EGR and blocking the tube and header. I'm about to sell the plates and forget about this!!
Is there any "civilized/human" way of doing this!?!?
Anyone with past experience please give me some pointers and tips
thanks all ...laterzzz
Old Aug 22, 2005 | 12:08 AM
stingercamaro's Avatar
Re: EGR removal
If you search under "EGR delete" shoebox has a how to guide with pics.
It isn't hard at all. All you have to do is remove the two bolts holding the EGR tube to the header, the two holding the EGR tubre to the motor, and the two holding the EGR pump to the motor. Attach the blockoff plates plug the vacuum lines going to the pump and your done. 10-15 minutes tops.
Old Aug 22, 2005 | 12:15 AM
Re: EGR removal
Please don't post the same question on two different forums.
Old Aug 22, 2005 | 07:59 AM
Re: EGR removal
Hmmm, I don't remember having a guide for removing the EGR.
Old Aug 22, 2005 | 08:25 AM
elisowski's Avatar
Re: EGR removal
Take a mirror and look behind the manifold on the passenger side. You will see all four bolts and their placements. After you see what your're dealing with, it will be sooooo much easier. If you take your time, 20-30 minutes tops. Just go in from the passenger side.
Old Aug 22, 2005 | 08:38 AM
Re: EGR removal
Why use a mirror, when you can use the photos on Shoebox's website:
http://shbox.com/1/egr1.jpg
The nuts on the studs are 1/2".
I wouldn't expect to find a "how to" for the EGR removal on Shoebox's site... like me, I think he doesn't quite see the reason for EGR removal.
Boss002
Jan 20, 2016 12:17 PM
Jlo
Jul 29, 2015 03:52 PM
RX Speed Works
Jul 24, 2015 02:25 PM
Dark Zeiro
Jul 19, 2015 08:25 AM
Jul 17, 2015 02:47 PM
