egr removal
Old Jun 2, 2004 | 10:03 AM
dirtybird96's Avatar
egr removal
is there any tricks to removing the egr on an lt1 without removing the intake?
Old Jun 2, 2004 | 10:56 AM
FLU
Guest
Posts: n/a
why would you think you have to remove intake? just reach your hand back there and unbolt it...
Old Jun 2, 2004 | 11:47 AM
Poik's Avatar
Is there anything you have to do so you don't throw codes? Some electrical stuff is messed up with my car, codes are for EGR and EVAP, but I think they are functional, just not getting power or something. If that turns out to be the problem.. I should just take it out instead of buying a new system from the dealer for it..
Old Jun 2, 2004 | 11:51 AM
cmking26's Avatar
I would remove egr before replacing it through dealer.$$$ If you have an OBD2 computer it may give ses light. OBD1 shouldn't give any codes.
Old Jun 3, 2004 | 07:33 PM
Z28Nut's Avatar
Just remember to block off the openings in the back of the intake and on the exhaust. I just had a friend weld up the ends of the tube after cutting off about an inch from each fitting. He also welded my cut-out in my off-road pipe, expanding the flare ends to fit over the cut-out. Bitched about the ceramic coating spitting like crazy as he welded it.
Boss002
Jan 20, 2016 12:17 PM
Jlo
Jul 29, 2015 03:52 PM
RX Speed Works
Jul 24, 2015 02:25 PM
Dark Zeiro
Jul 19, 2015 08:25 AM
Jul 17, 2015 02:47 PM
