EGR question? Please help
Old Oct 19, 2003 | 08:11 PM
ead94z28's Avatar
Question EGR question? Please help
Should I have any vacuum at the back of the solenoid or at the back of the EGR valve? I have suction if I take the rubber elbow off the drivers side intake manifold but I have none at the back of the EGR valve or the solenoid.
Old Oct 19, 2003 | 09:24 PM
There will be no vacuum out of the EGR solenoid, hence no vacuum at the port on the EGR valve, unless the valve is actuated by the PCM. Since it doesn't use EGR at idle or at WOT, you aren't going to see any vacuum just by pulling the hose off at idle.
Or did I miss the point of your question?
Old Oct 19, 2003 | 09:36 PM
ead94z28's Avatar
You got it. Thanks injuneer.
Noenav
Mar 1, 2019 07:38 AM
edman
Mar 13, 2015 09:39 PM
97SSdude
Dec 31, 2014 07:43 PM
cmdeshon
Dec 27, 2014 10:06 AM
thenewkid
Nov 18, 2014 12:57 PM
