EGR Problem
EGR Problem
Well my stupid egr tube is still not fitting onto my LT's ive tried and tried and I have managed to totally F up the tube that runs to the back of the intake manifold to the header so my question is can i just block off those two holes and leave the EGR valve intact? or do I have to remove that and also block it off I need to use the car tomrrow, and have two plates but not one for the egr valve.
I had a similar problem where the EGR tube wouldn't clear the tranny dipstick enough to make the connection. I ended up pulling the header out of the car, heating up the EGR fitting with a portable Sears propane torch and bending the EGR pipe with a piece of metal rod an inch in the direction of the firewall. After that, everything connected without a hitch.
