EGR prob
Old Mar 7, 2007 | 09:38 PM
burnout96's Avatar
EGR prob
I have a 94 z, took it to the shop 2day, they are testing 2mrw to see if i need the base egr or the 95 n up one with the soleniod, how do i find out what i need and is it something i could install myself?
Old Mar 8, 2007 | 12:16 PM
The LT1's do not use a solenoid operated EGR valve. They are opened by a vacuum line, using a pulse width modulated vacuum solenoid, which is a separate part. The configuration is the same for all years, 93-97. There may be a difference in the part numbers for the actual EGR valve, based on system backpressure, but the way the valve functions it still the same.
All years look exactly like this:
http://shbox.com/1/egr1.jpg
Old Mar 8, 2007 | 01:52 PM
burnout96's Avatar
thank you, i was doing some reading so i take it in a way if i delete the egr and get the block off plate, it will have no affect to any performance issues? as long as it is programed out?
Old Mar 8, 2007 | 02:39 PM
2000GTP's Avatar
You'll definitely need to get the EGR programmed out, otherwise you can count on an SES light. Also, removing the EGR can lead to a possible performance degrade from knock retard if you receive detonation from excessive combustion temps.
Old Mar 8, 2007 | 11:00 PM
Since he has a 94, there's only about a 1 in 5 chance that he will get a code when deleting the EGR, at least DTC 32. If he deletes the solenoid, he needs a resistor.
Old Mar 8, 2007 | 11:02 PM
Zeueses 97 RamAir's Avatar
there
what injuneer said
marlar98
Oct 21, 2015 02:02 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
MDZ28
Sep 7, 2015 09:16 PM
Pwilson59
Sep 3, 2015 08:47 PM
Jlo
Jul 29, 2015 03:52 PM
