EGR gaskets?
EGR gaskets?
When blocking the EGR do you need new gaskets for the 2 plates on the intake? Or can you just pull off the old gaskets and use soem RTV? What RTV would you reccomend (black or copper)?
I used copper on mine.
I had an EGR blockoff plate that I bought from GM but then I ran into the OTHER hole in the manifold so I got some hi temp gasket material and took the metal hose out of its bracket, cut me a gasket and used the bracket and my gasket as my blockoff.
