EGR delete Need Help
Old Mar 29, 2008 | 12:35 AM
TAEnvy's Avatar
Hey Guys Im in the middle of a cam swap and the manifold is out getting powder coated and when I was pulling it off I noticed there is SO MUCH **** conneceted to the manifold so I want to delete a bunch of it.
I have a 97 Z28 and the EGR and Evap are already deleted from the PCM, but they are still hooked up. So what exactly do I get to delete what ports besides the ones on the back can I plug or weld closed?
Sorry but on that crap I cant tell FPR, from Evap, from EGR things and pics would be helpful to.
Old Mar 29, 2008 | 12:41 AM
ss.slp.ls1's Avatar
You will need to get block off plates, total of three. One for where the egr valve goes. And the other two for where the tube that connects the passenger side exhaust manifold to the back of the intake manifold. You can remove the egr solenoid and cap off where it connects to the intake manifold on the drivers side. If you have tunned out AIR you can remove the air pump vacuum solenoid and cap off where it connects to the air diverter valve and the intake manifold.
Old Mar 29, 2008 | 12:43 AM
Wild1's Avatar
http://shbox.com/1/egr1.jpg
From Shoebox's website. All can go. Plug off the hoses and get 3 EGR block off plates. They don't cost much.
Old Mar 29, 2008 | 10:46 AM
endobong's Avatar
I just installed LTs and only used the AIR/EGR plates I still have the tear drop shaped plate that would of gone on the stock manifolds right?
Old Mar 29, 2008 | 11:27 AM
The cover for the hole on the header or manifold is an oval, with a single hole in it. If your headers didn't have an EGR connection on #8 primary, you don't need that plate.
Old Mar 29, 2008 | 10:15 PM
The_Bishop's Avatar
I was under the impression that all you really needed to block off on the manifold was the actual flange the EGR mounted to; the other hole didn't matter.
marlar98
Oct 21, 2015 02:02 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
MDZ28
Sep 7, 2015 09:16 PM
Pwilson59
Sep 3, 2015 08:47 PM
tnmotown
Aug 10, 2015 11:52 PM
