egr delete
Old May 1, 2013 | 08:17 AM
Chet1185's Avatar
egr delete
How bad will my TA run if I delete the egr/air but don't get it tuned out right away?
Posted from Camaroz28.com App for Android
Old May 1, 2013 | 09:00 AM
RamAir95TA's Avatar
Re: egr delete
You'll get an SES light but won't see any difference in how the car runs (assuming you properly install the correct block-off plates and cap the vacuum line to the solenoid).
Old May 1, 2013 | 09:26 AM
Chet1185's Avatar
I'm using the plates and will cap the lines. I read that if you leave the egr solenoid plugged in you won't get a code, is that right?
Old May 1, 2013 | 11:09 AM
NJ-LE's Avatar
Re: egr delete
Chet1185:
"I'm using the plates and will cap the lines. I read that if you leave the egr solenoid plugged in you won't get a code, is that right?"
Yes for 1995, but ... Without changing the tune, under certain engine loads the PCM will add spark advance because it thinks the EGR has operated and diluted the cylinder mixture with exhaust gases. Because the mixture isn't diluted the extra advance will cause detonation. Normally the knock sensor signal will tip off the PCM and it will then pull the additional EGR advance plus much more timing because of the knock. Your highway mileage will be much worse than it is already.
Old May 1, 2013 | 11:19 AM
Chet1185's Avatar
I will eventually get it tuned after I make sure it runs good. It is a new rebuilt stock engine .030 over. This is my first build and I just want to be sure is runs OK.
Anyone every use madtuner.com?
Old May 1, 2013 | 03:24 PM
Re: egr delete
EGR is generally only required if you are lugging the engine in the wrong gear at low RPM. If you don't drive like that, you shouldn't see the EGR system operating too often. EGR does not operate at idle, does not operate at WOT and does not operate over 3,500RPM.
AIR only runs for a couple minutes at startup, to help the cat heat up faster. Deleting it will have no affect on the engine operation.
For EGR, there are two codes - DTC 27 for the EGR vacuum solenoid, and DTC 32 for lack of EGR flow. You can avoid DTC 27 by leaving the solenoid plugged in, or disconnect it put something like a 1,000ohm resistor across the pins in the harness connector. DTC 32 is hard to beat (can be done without a tune, but tricky) but the diagnostic is not really very sensitive in the OBD-I cars. You may never get a code. I'd guess that less than 1/2 actually get the code showing up.
Old May 1, 2013 | 03:51 PM
jloshotz's Avatar
Re: egr delete
Originally Posted by Chet1185
Anyone ever use madtuner.com?
I run a MadZ tune, no issues; all went great
marlar98
Oct 21, 2015 02:02 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
MDZ28
Sep 7, 2015 09:16 PM
Pwilson59
Sep 3, 2015 08:47 PM
tnmotown
Aug 10, 2015 11:52 PM
