egr blockoff plates
Old May 30, 2004 | 02:18 PM
1badasZ's Avatar
egr blockoff plates
where do i get some for my car? and do i do away with all the A.I.R stuff too?
Old May 30, 2004 | 02:48 PM
Yby4n95Z's Avatar
I to will be doing pacesetter longtubes that DO NOT have emissions hook ups and need to know what parts and install is invloved with removing A.I.R and EGR. Any instructions would be helpful. The actual header install instructions I have.
Didn't mean to highjack your thread but thought your might want some more info to.
ADam
Old May 30, 2004 | 03:53 PM
Spinner's Avatar
The air pump, you unbolt and throw away anything attached to it. Easy enough.
EGR plates can be had at SJM. Mine are top notch pieces.
http://www.mycamaroz28.homestead.com/
Old May 30, 2004 | 04:36 PM
After you remove it, you might want to use a 5/8" vacuum cap to close off the nipple on the inlet air duct for the A.I.R. supply line.
Old May 31, 2004 | 10:04 AM
magnumv8's Avatar
I just made my own block off plates. I just took the old gaskets and traced them on a peice of 1/4 inch steel and cut and drilled them. They turned out great and didnt cost anything.
Old May 31, 2004 | 11:14 AM
FLU
Guest
Posts: n/a
Moreperformance has these plates -which is where i got mine for $9.95 each my question is where can i find a plug for the holes on top of the header where the egr bolted up too?
Old May 31, 2004 | 11:27 AM
MTL_Z28's Avatar
I can't seem to find it on their website. Where exactly will I find them?
Old May 31, 2004 | 11:53 AM
CamaroBoy96Z28's Avatar
Thats where I got mine too. Great Pieces.
GREEN3112
Feb 10, 2019 09:19 PM
Ericksd
Jan 20, 2016 06:07 PM
95blkss
Sep 22, 2015 03:18 PM
Daluchman1974
Sep 11, 2015 06:12 AM
Pwilson59
Sep 3, 2015 08:47 PM
