Egr Blockoff
Yes you can do it with the intake still on the engine. Its not hard but a pain because of the whole engine under the cowl thing. I did it with the intake on in about 20 minutes.
I also got my plates from Steve Monte which is that link posted by anaik.
Originally posted by 94TEALz
Hmmm egr blockoff never heard of it before. Does it just get rid of the whole egr system? someone plz explain Im wondering if this could cure my egr problems?
Re: Checking the EGR
Originally posted by TArider21
If you pull the vacuum line of the EGR is the idle supposed to stumble and the engine die, or is the idle supposed to remain the same?
if you pull the vacuum off the valve, nothing will happen. the valve works when vacuum is applied to the valve. idle wont stumble or anything.
If you wanna block off the egr the cheap way, just disconnect the vacuum line to it and plug it with a small screw . without vacuum, the valve can never open.
sleeperZ96BT
Sep 9, 2015 08:28 AM
