Egr Blockoff
Old Sep 5, 2003 | 05:49 PM
TArider21's Avatar
Question Egr Blockoff
wHERE CAN I GET AN EGR BLOCKOFF PLATE FROM? AND, WHEN I GET IT, HOE DO I GO ABOUT INSTALLING IT?
Old Sep 5, 2003 | 06:18 PM
anaik's Avatar
HERE'S A SITE THAT SELLS SOME NICE ONES.
http://www.mycamaroz28.homestead.com/
Old Sep 5, 2003 | 07:11 PM
TArider21's Avatar
Question EGR Blockoff
Can I remove and block off the EGR with the intake still on the engine?
Old Sep 5, 2003 | 08:46 PM
CamaroBoy96Z28's Avatar
Yes you can do it with the intake still on the engine. Its not hard but a pain because of the whole engine under the cowl thing. I did it with the intake on in about 20 minutes.
I also got my plates from Steve Monte which is that link posted by anaik.
Old Sep 5, 2003 | 09:30 PM
TArider21's Avatar
Talking EGR Blockoff
Cool, Thanks for the help!
Old Sep 5, 2003 | 09:36 PM
94TEALz's Avatar
Hmmm egr blockoff never heard of it before. Does it just get rid of the whole egr system? someone plz explain Im wondering if this could cure my egr problems?
Old Sep 5, 2003 | 09:55 PM
All you do is remove the EGR solenoid and tube from intake to the exhaust manifold and block off the 2 holes in the intake with plates or something similar.
Old Sep 5, 2003 | 11:25 PM
phoenix916's Avatar
I made my own plates. For the tube in the back all I did is take it off cut off the tube and put a nickel in it. I used some silicone sealer to hold it in and for 5 cents it's sealed.
Brett
Old Sep 6, 2003 | 09:11 AM
TArider21's Avatar
Question Checking the EGR
If you pull the vacuum line of the EGR is the idle supposed to stumble and the engine die, or is the idle supposed to remain the same?
Old Sep 6, 2003 | 10:56 AM
JDBlaze85's Avatar
Re: Checking the EGR
if you pull the vacuum off the valve, nothing will happen. the valve works when vacuum is applied to the valve. idle wont stumble or anything.
If you wanna block off the egr the cheap way, just disconnect the vacuum line to it and plug it with a small screw . without vacuum, the valve can never open.
Old Sep 6, 2003 | 07:42 PM
Josh-'04 GTO's Avatar
Very quick service by Steve at SJM Manufacturing as posted above. Two thumbs up. The plates weigh practically nothing, so you save a pound or two by getting rid of the valve and tube too.
Old Sep 6, 2003 | 08:40 PM
PoorMan's Avatar
I ordered the plates from the site listed above. Pics in sig under the "powdercoated plenum" section. They are nice. Not like you are going to see them though.
Jeff D.
Old Sep 6, 2003 | 08:47 PM
anaik's Avatar
[QUOTE]Originally posted by PoorMan
Jeff D.
[/QUOTE
Or anybody else.
marlar98
Oct 21, 2015 02:02 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
MDZ28
Sep 7, 2015 09:16 PM
Pwilson59
Sep 3, 2015 08:47 PM
Jlo
Jul 29, 2015 03:52 PM
