EGR and AIR delete
Old Jun 8, 2009 | 11:02 PM
94 355 lt1's Avatar
EGR and AIR delete
I'm rebuilding my lt1 and decided to do a EGR and AIR delete.Besides a tune and the block off plates is there anything else I need to Know about or do?
Old Jun 8, 2009 | 11:22 PM
"Plates" only cover the various holes for the EGR components. If your headers have AIR connections, or if you are still running stock manifolds, you need a plug for each side. And you will need to cap off the nipple on your air inlet duct where the hose that supplies the AIR pump connects. On the AIR pump, you don't need programming - as long as there is a good fuse in the AIR pump circuit, unplugging the pump will not set a code (OBD-I only).
Why not add a "signature" with basic info about your car - year, model, engine, trans and any major mods?
Old Jun 9, 2009 | 11:13 AM
94 355 lt1's Avatar
Ok thanks! I'm new at all of this but I'll try to figure out the signatue Info, thanks again
Old Jun 9, 2009 | 11:45 AM
meissen's Avatar
https://www.camaroz28.com/forums/pro...=editsignature
Just trying to help.
Noenav
Mar 1, 2019 07:38 AM
k1996z28
Jan 21, 2015 07:22 AM
95chwagon
Jan 13, 2015 09:19 PM
97SSdude
Dec 31, 2014 07:43 PM
MIGHTYMOUSE
Aug 29, 2002 09:18 AM
