ECM code 42, opti?
Old Dec 15, 2007 | 02:42 PM
  #16
All you had to do to avoid taking the Opti off was look at Shoebox's code list:
DTC 42 = Ignition Control (IC) circuit (shorted or grounded circuit)
There is no way the high voltage section of the Opti (cap/rotor) would cause that code. There is a fairly detailed logic diagram in the factory manual for finding the problem indicated by DTC 42, which can be caused by:
-faulty connection on the white wire from the PCM to the ICM
-grounded IC circuit between PCM and ICM
-faulty ICM
-faulty circuit on various connections to the ICM
-faulty PCM
Old Dec 15, 2007 | 02:53 PM
  #17
FASTFATBOY's Avatar
-faulty ICM
-faulty PCM
Ummmm....OK, It says in my manual what a 42 is, it also says to clear the code and drive the car and if it does not come back it is an intermittent problem.
The spare distributor cap fixed it, or so I think. Runs great! I just drove it 20 miles kinda hard...seemed ok. But I will take a spare ICM with me to the track tomorrow.
I am going for my lifelong goal tomorrow, 10.90 in an all motor pumpgas streetcar. Wish me luck.
David
Old Dec 15, 2007 | 02:57 PM
  #18
Originally Posted by FASTFATBOY
..... Now under hard load it misses and pops out of the exhaust. Has stored a code 42....any ideas?
Any help appreciated.
David
David
Apparently you found no value in my attempt to help. Most of the diagnostics in the manual say to clear the code, and see if its intermittent.
Never mind.....
Old Dec 15, 2007 | 04:02 PM
  #19
FASTFATBOY's Avatar
Never mind.....
Well I kinda took it the wrong way I guess, like instead of asking,you wanted me to go straight to Shoebox's website.
Either way it seems ok, and thanks for the input.
David
Old Dec 15, 2007 | 04:11 PM
  #20
mdacton's Avatar
Good luck
you have any after market ignition stuff? msd box or anything?
I have never used one and never had an opti problem....Only time I replaced on was when I had a small fire been 10 years and alot of RPM
Old Dec 15, 2007 | 04:15 PM
  #21
FASTFATBOY's Avatar
Originally Posted by mdacton
Good luck
Yeh I have an Accel 300+, I have heard that higher powered ignitions will burn up the cap and rotor but I thought it was BS.
David
Old Dec 15, 2007 | 04:16 PM
  #22
ABA383's Avatar
Good luck tomorrow Dave!!! Don't forget to tighten up the rear shocks and add some psi in those big tires!!!
--Alan
Old Dec 15, 2007 | 04:54 PM
  #23
The Engineer's Avatar
Good to hear it's running OK again. Make sure all the ground wire terminals are tight there on the coil/ICM studd.
David
I have a MSD 6A and didn't notice any cap/rotor issues the last time I had everything apart.
How is the weather down your way in Bama, or LA to be more exact? Here in the midwest (Ed Wright country) we've got some snow and ice. And, what track are you headed to?
WD
Old Dec 15, 2007 | 06:14 PM
  #24
FASTFATBOY's Avatar
WD
Tomorrow is gonne be one of those days you only get EVERY great once in a while. FOrecast for Hattiesburg Miss
High of 50 Sunday, low of 35 Sunday night, 50% Humidity. Track is only 150 above sea level!!
Man I am like a kid waiting on Xmas!!
David
dplatt3
V6 Tech
Apr 30, 2015 10:44 AM
Iamherefornow
Jan 26, 2015 04:57 PM
babyIroc87
3rd Gen / L98 Engine Tech
Aug 8, 2002 04:07 PM
91Bird305
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
