easist way to install heads and cam??
Old Apr 8, 2006 | 10:23 AM
JeremyKweens's Avatar
Option 1: Leave the motor in and pull off all the needed stuff and do the heads/cam this way.
Option 2: Get the biotch on a hoist and pull of the entire front end (motor, front suspension, wheels, tranny, ect) and then go to town while the motor is out of the car
ps. I have access to a hoist so option 2 can happen. However, I don't really have much knowledge when it comes to doing heads and a cam on an LT1 so with each option can you guys list what items would need to come off of the car??
Thanks alot guys!
Old Apr 8, 2006 | 05:47 PM
GhostZ's Avatar
Re: easist way to install heads and cam??
Option #1. Buy a Haynes and/or Chilton and go from there. Take your time and everything will go well.
http://shbox.com/page/index.html Check there for how-to's.
Old Apr 8, 2006 | 07:19 PM
Eddie Z-28's Avatar
I vote option #2. I was gonna do your option #1 then the night after I got done pulling the heads off the car, I literally woke up the next morning and said I was gonna do it right. Get the bottom end done, it's a couple hundred extra bucks well spent.
Old Apr 8, 2006 | 08:03 PM
Loadre's Avatar
I say leave the motor in the car. Done about 5 this way.
Old Apr 10, 2006 | 11:11 AM
Probably an all weekend long job then hey??
Old Apr 10, 2006 | 11:52 AM
Loadre's Avatar
Roughly, Depends on how experienced you are at it.
Old Apr 10, 2006 | 12:09 PM
Javier97Z28's Avatar
Moderator
all I can say is doing it in the car is a hell of alot dirtier :/
I think next heads/cam install I do, the motor is coming out the bottom.
Old Apr 10, 2006 | 12:31 PM
turbo_Z's Avatar
Heads and cam is such a back killer. If you have the tools then you should seriously consider dropping the motor out the bottom. 99% of the hang ups during that kinda work are all because of the cramped work space.
birdblack
Dec 30, 2014 06:59 PM
Queens94z28
Nov 20, 2014 06:03 PM
NED4SPD
Sep 16, 2002 10:45 PM
yosshimura
Aug 12, 2002 06:47 AM
