easiest way too drain coolant
Old 03-05-2005, 12:04 AM
simple's Avatar
swapping optis in a week or 2 (again lol)
i have an electric water pump, is there a way i can use that too my advantage too drain the coolant?
would i be best off too drain it from the block with the pump running, assuming the thermostat is open?
anyone have any tricks to draining it without a huge mess that i usually end up with?
simple is offline
Old 03-05-2005, 04:15 AM
1racerdude's Avatar
Re: easiest way too drain coolant
There are block drains on both sides of the block.Pass side is the knock sensor the drivers side is in the same place with a pipe plug.
Use a 6 point socket and 1/2" drive ratchet on the drivers side it is tight and a good open end on the knock sender.
The radiator has a valve.
1racerdude is offline
Old 03-05-2005, 04:43 AM
West South Central Moderator
AdioSS's Avatar
you'll be replacing the hoses with new ones anyway while you have the system open, right? Just cut the bottom hose
AdioSS is offline
Old 03-05-2005, 08:42 AM
moparman's Avatar
Pull the bottom hose off, and have a catch pan in position. You'll be surprised how fast it will drain.
moparman is offline
Formula Steve
09-19-2023 08:31 AM
Jeff1904
06-05-2016 05:00 PM
PopoFormula
10-12-2015 04:19 PM
Bigtoyz97
09-21-2015 01:44 PM
Pwilson59
09-03-2015 08:47 PM
Quick Reply: easiest way too drain coolant
