early/late lt1?
Old Oct 27, 2007 | 05:17 PM
duals's Avatar
early/late lt1?
I am planning on building a 383 this winter and was wondering what the differences between the 94 and 95 block are and if you can just change the timing cover opti. I have a 95 with a buddy that has a 94 that needs rebuilding and would like to be able to pull and install motors in the same weekend. Any info is grately appreceated.
thanks in advance,
duals
Old Oct 27, 2007 | 06:32 PM
JooneJune's Avatar
1994- nonvented opti (cam dowel is different, timing cover different)
1995- vented opti
1994 dash harness different from 1995 dash harness.
Year of the engine harness/pcm must match year of dash harness.
everything else should be the same...
Old Oct 27, 2007 | 06:52 PM
duals's Avatar
so all I need to do is keep 95 timing cover and vented opti and I can use 94 block for my build, correct?
thanks again,
duals
Old Oct 27, 2007 | 07:31 PM
96camaroSS's Avatar
Duals. What part of Iowa do you live in?
Old Oct 27, 2007 | 07:35 PM
Dave89IROC's Avatar
yes, blocks are the same 92-97
Old Oct 27, 2007 | 07:56 PM
duals's Avatar
location
I live in Decorah, (NE corner)
Old Oct 27, 2007 | 08:00 PM
JooneJune's Avatar
yeah, 1994 block... 1995 timing cover/timing gears, 1995 opti, and you have to alter the dowel on the cam to complete the vented swap.
Old Oct 28, 2007 | 04:56 AM
sykodave's Avatar
all lt1 blocks are the exact same. with the exception of the vette's which are a 4 bolt main.
Old Oct 28, 2007 | 09:57 AM
duals's Avatar
thanks for the info guys. planning to move ahead as originally planned.
oldschool
Feb 9, 2016 09:21 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Noer
Feb 28, 2015 11:29 AM
InfernalVortex
Jan 17, 2015 09:35 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
