early/late lt1?
early/late lt1?
I am planning on building a 383 this winter and was wondering what the differences between the 94 and 95 block are and if you can just change the timing cover opti. I have a 95 with a buddy that has a 94 that needs rebuilding and would like to be able to pull and install motors in the same weekend. Any info is grately appreceated.
thanks in advance,
duals
thanks in advance,
duals
1994- nonvented opti (cam dowel is different, timing cover different)
1995- vented opti
1994 dash harness different from 1995 dash harness.
Year of the engine harness/pcm must match year of dash harness.
everything else should be the same...
1995- vented opti
oldschool
Feb 9, 2016 09:21 PM
