dyno, should i be disapointed?
Old Jan 28, 2006 | 05:22 PM
Foxls1's Avatar
dyno, should i be disapointed?PICS
stock 162k lt1 stock heads
NO TUNING, STOCK BUILD
hotcam, LTs, hooker catback
M6
3.42s
cold air kit, thats it.......
299.98HP @5500rmp dont know why they would not run it any higher like i asked, its got a killer valve train, anyway.....
299.98 @ 5500
328.34TQ @ 4000
A/F was right @ 13 across the board til 5k then richens up slightly
TQ curv starts @ 300lbft@2500 and climbs to 328 @ 4k and drops off after that to 319@5500
what do yall think???
Old Jan 28, 2006 | 05:26 PM
buzz12586's Avatar
Re: dyno, should i be disapointed?
I assume you are running stock heads???
Old Jan 28, 2006 | 05:29 PM
Foxls1's Avatar
YES STock heads
Old Jan 28, 2006 | 05:35 PM
96flame's Avatar
With some tuning you should be happy with the results
Old Jan 28, 2006 | 05:42 PM
96capricemgr's Avatar
Untuned I bet the rev limiter is fast approaching at those rpms.
I put 290 down with a good bit smaller cam through a high stalled auto with a heavier drivetrain with a rich AFR 11.8-12.1 and on a Superflo no less which reads lower than a Dynojet. Torque was hard to get a good bead on due to the TC and a downshift issues but was over 350 at 4100rpms and this cam probably peaked back down around 3500.
Get the car tuned you will be signifigantly rewarded.
Old Jan 28, 2006 | 06:43 PM
SnakeOiler's Avatar
They should have at least taken it to the limiter. HP is still climbing, it should peak at around 6000-6200 rpm. As already mentioned, a tune is in need.
No, you should not be disappointed with what you have there.
Old Jan 28, 2006 | 06:46 PM
Foxls1's Avatar
thnx for the encouraging words, i love my TQ curv tho , it just says "gimme a bottle" lol
Old Jan 28, 2006 | 06:50 PM
LagunaS3's Avatar
I would be happy, isn't that basically what the LT4 makes...and you're making it without the heads.
Old Jan 28, 2006 | 06:54 PM
The LT4 did not come with the HOT cam though and that is what he has here.
Old Jan 28, 2006 | 08:02 PM
96cam4ro's Avatar
You should have more power - do you have the 1.6 Rockers as well or just the Hotcam?
Old Jan 28, 2006 | 08:42 PM
jkipp84's Avatar
Without a tune, I'd say you're not doing too shabby.
Old Jan 28, 2006 | 09:10 PM
Foxls1's Avatar
stock 1.5 rockers only LTs and a hotcam
Old Jan 28, 2006 | 09:17 PM
Jameslt1TA's Avatar
I would get some 1.6 rockers and get it tuned. Headers tend to make more noise causing the stock tune/knock module to pull more timing than normal and that could really hurt hp.
You could maybe gain 30 or so horse from tuning and 1.6 rockers.
fift5
11
Oct 1, 2015 10:31 AM
Daluchman1974
Sep 11, 2015 06:12 AM
tdigger9899
Sep 7, 2015 10:56 AM
RallyRed701/2
Jul 27, 2015 02:55 PM
Strick
Jul 14, 2015 07:28 AM
