Dyno #'s SUCK! Ideas why?
Old May 26, 2003 | 11:00 PM
  #16
Draco's Avatar
Originally posted by oldschool
Payam...I asked your opinion, and thanks again. If you would be willing to help in the tunning, I would be greatfull. Good point on the flow of the heads
The pull was made in forth
The car has 172,000KM (not sure in exact miles) but I didn't think that mattered because at 169,000, the car went 13.9 @103. I would assume that the bottom end, although not great, isn't the limiting factor in my #;s
Did you put new lifters in when you did the cam swap? My lifters seemed OK at 230 000km, but that doesn't mean yours aren't crapping out.
Also are you still running your dying rear end? I wonder if your rear is in bad enough shape to drain HP...
Old May 26, 2003 | 11:48 PM
  #17
sideways_Into_3rd's Avatar
let me look at ur dyno sheets next time i see u ...
i bet with a little tuning and revving it higher on the rollers u could see 350 .. thats only 15 hp .. i can see 15 hp in ur tune + more revs easy
should've told harvey to rev it higher ! sometimes he doesnt listen .. tell him u either rev to 6500 or u aint gettin paid
he wouldnt rev my car past 6500 when i dynoed 371 though at 6500 my hp was still on the rise ... 5900 is too low .. ur cam should peak around 6200 and start dropping around 6400
let the track tell the tale ! come make a few passes ... the mph + the weight of ur car will tell ur hp fairly accurately.
oh and i dont dare mess with the work of god himself ! he can tune ur car as he sees fit ..
Old Jun 3, 2003 | 03:33 AM
  #18
SS RRR's Avatar
I say if you are near a track, take it there and see what it'll do.
I have little faith in dyno numbers compared to track times.
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
TitoPR221
May 26, 2015 12:20 AM
NewsBot
May 10, 2015 08:10 AM
BLK1997Z28
May 7, 2015 03:01 PM
armedtrigger
Feb 24, 2015 08:30 PM
